Pac2007-03-28 16:50:08 // 14964
Üdv Mindenkinek!
Át tudom érezni a dolgot....:-(
Én tavaly októberben jártam úgy, hogy kb. 1 óra alatt repedt be a szélvédő bal oldala cirka 30 centit...
Ok: egy apró köfelverődés, de olyan helyen amit csak nagyítóval lehet látni. A gumi tömítés mellett 1 mikrométerre...
Nekem csere volt.
Szerintem a Tiéd vagy megfeszülhetett (rosszul rakták be) vagy neked is egy nagyon apró kőfelverődés :-(
Nézted?
mesa2007-03-28 14:01:54 // 14963
OFF
Water temperature display :.
The water temp rises too slowly, hitting 90c° only after 10Km (driving
about 90Km/h with 5c° outside), when temp reaches 90 it suddenly drops
to 75-80 and then rises a little but usually is always below 90c°.
Reason:
Alfa uses a different way of showing the temperature compared
to i.e. Opel, Audi, VW. I guess Seat is VW so......
The difference is that in fact the temperature always goes up and
down because there is a thermostat (in all cars!!) that opens when
the cooling circuit reaches a certain temperature like 90dgr.
When the thermostat opens, a whole lot of relativaly "cold" cooling
drops from 90 to 70-75dgr.
Alfa shows this immediately on the temperature indicator whereas many
other cars measure an AVERAGE temperature that goes up and down very
slowly and certainly will not show the peaks like the Alfa way.
I guess this is done because the "normal" car driver will get in panic
and goes and see their dealer to check if nothing is wrong and Alfa is
of the opinion that Alfisti, as real, true car drivers, as enthousiastic
and knowledgeable car dirvers and can "see through" this.
So, forget about bothering the dealer, just enjoy your Alfa and keep
a regular eye on all engine fluids; don't forget the fuel tank ;-)
Thanks to Gert-Jan from Holland for this info!
alfa156.net
kertecs2007-03-28 12:44:21 // 14962
Amiket én hallok ismerősöktől... minden vasnak megvannak a nyűgjei
Miután megvettem a 155-öt, fel-felvillant az injektor hibajelzőm, a srác bepróbálkozott a Stoll-nál (akkori pécsi márkaszervíz): hagyjam ott egy két napra. Na persze...
Egyébként termosztát csere volt a megfejtés
csocsi2007-03-28 12:40:10 // 14961
Érdekes dolgok. Most lehet, hogy gonosz vagyok, de ezek szerint a német ipar kiválóságainak is vannak gondjaik :))
Mindenesetre tanulságos a történek.
kertecs2007-03-28 12:33:29 // 14960
Surcy2007-03-28 08:11:48 // 14959
Szaszto!Hasonló remek élmény?Novamberben cseréltettem szélvédőt.Vasárnap használtam a vasat semmi,hétfön pihent a garázsban,kedd délelött beülök a vasba kitekintek a szélvédön és egy jó 20-25 cm es REPEDÉS tekint vissza az anyós olbalon.Sikitó frászt kaptam.Gyorsan elmentem mgcsináltatni 5000-ért.De,hogy MITÖL lövésem sincs!
Kazes☻2007-03-27 22:58:57 // 14957
Nem sok minden változik,csak olykor-olykor, kisebb fejlesztések, ám ez a probléma az én '83-as Giuliettámmal is előfordult már. Ezek ilyenek. ! ? :-)))
LuckyMan2007-03-27 22:31:47 // 14956
LuckyMan2007-03-27 22:30:51 // 14955
Valszínü neked is a vm lesz rossz.A motorhőfok nekem is dettó ugyan ezt produkálja,de én vettem bele gyári termosztátot egy vagyonért és semmi sem változott.Ezek a motorok egy kicsit tul vannak hűtve és azért nem megy fel a hőfok.Ha egy kicsit hajtom a vasat már mindjárt helyreugrik.
Pac2007-03-26 23:01:59 // 14954
Hi!
Csak azon elmélkedtem, hogy hátha így jobban megérné, de ha 400e-t elmegy a kicsike, akkor tényleg felesleges.
Ja, azt gondoltam, hogy nem occsó mulaccság :-)
Akkor vegyétek a motorcserét költői kérdésnek...:-)
Thx!
Üvegtigris2007-03-26 19:59:53 // 14953
Igen, a kodolás még érdekes téma lesz!
csocsi2007-03-26 19:57:04 // 14952
Mike.-nak lett már csinálva, úgy tudom jól bírja neki.
andraska2007-03-26 19:53:42 // 14951
sziasztok!! van valakinek tapasztalat vezérlés modosito,jav.készletről???jo vagy felejtős!!irjatok
andraska2007-03-26 19:51:23 // 14950
ha bicskás a kulcs akkor rázos 40 papir hegyalja kft.4 nap és megvan +rá kell kodolni a kocsira az még 5 ropi ha megvan a kod kártya +riaszto kod!!!
uaz146ti (kispali kisebbik fia)2007-03-26 12:17:13 // 14949
üdv!
tegnap történt egy kis baleset a kulcsommal, konkrétan úgy széttört mint a ropi..
Volt itt trélerezéstől elkezdve minden...
Most állok neki valahogy kiműteni a kulcs másik felét, ha ehhez van valami ötlet azt szívesen venném + arra lennék kiváncsi, hogy új kulcsot hol tudok csináltatni, mennyibe fáj és mennyi idő míg elkészül.
előre is thx.
Ferke2007-03-26 10:52:57 // 14948
LOL!:))) Mondjuk egy kpl. vadiúj motor berakása sok apró problémát csírájában ölne meg!:)))) Csak nem annyir olcsó!:))))
Marklar1552007-03-25 23:37:25 // 14947
Dunakeszi.
http://fiat-nemet.uw.hu/
Pac2007-03-25 16:15:29 // 14946
Ok, köszi a szakértést! :-)
granturismo2007-03-25 16:05:56 // 14945
Motort majd 400ekm körül.:-)
granturismo2007-03-25 16:05:10 // 14944
Na azért a motorcsere az durva lenne. Még vezérműszíj csere, hosszbordásszíj meg annak a feszítője ami megnézendő. Meg a kuplung, a fékek. Szűrők, olajcsere fékfolyadék fagyálló ellenőrzés ilyesmi, de motort azt ne:-)
Alfi_1452007-03-25 15:13:59 // 14943
Sziasztok!Valaki tudna nekem segíteni?Szolnokon v. környékén(50-100 km-en belül)tud valaki egy jó Alfa szerelőt,aki jártas a TS motorokban?Dízelhangos problémám van nekem is,de nem tudni konkrétan,hogy mi okozza(hidegindítás után kb. 2 mp-ig dízeles,utána elhallgat,majd ahogy melegszik a motor újra előjön a dízel hang)!A termosztátom sem tökéletes(üzemi hőfok kb.75 fok),de ha nem megyek az autóval,járó motornál álló helyzetben felmegy a hőfok 90 fokra,és elhallgat a dízel "ördög"!Van valakinek valami ötlete a megoldásra?
csocsi2007-03-25 14:45:17 // 14941
Hát azért motrot ne cserélj :))
Pac2007-03-25 14:44:06 // 14940
A véleményeteket és a tanácsotokat szeretném kérni:
TS motor 200 e-s szervízénél (az általános: gyertya-, vez. módosító + görgők cseréjén, olaj, egyéb folyadékok és szűrők cserén) kívűl miket kell még átnézetni vagy cseréltetni?
Vagy egyáltalán érdemes lenne a komplett motorcsere?
(Bocs, ha hülyeséget kérdeztem).
mesa2007-03-24 21:06:32 // 14939
Szerintem jó helyre írtál! Nagy a valószínűsége.
andraska2007-03-24 20:57:50 // 14938
sziasztok!! nekem 2002. 156.1.6.ts van és most jelentkezik valami fura csörgö hang mit a hidrotőke remélem nem az.!!! hogyan lehet megtudni mi szol a motorban??csak inditáskor csinálja!!
Tocsa2007-03-24 13:04:51 // 14937
GOLDEN LODGE Forever !!!!!!!! :)
Piritu - 1.000.0002007-03-24 12:35:55 // 14936
Szerintem nem. Nekem ami be lett téve "örök" volt, később már nem kellett kicserélni, pedig a 146-al vagy 140ezret mentem vele utána. A hang úgyis jelzi ha gondolkodni kell a cserén. Amúgy ha elkezd kerepelni, akkor is simán lehet még vele menni, baj nem lehet, "csak" csúnya a hangja.
Egyre inkább azt hiszem, hogy az olajon múlik minden nem a használaton. Szerintem a gyárilag berakott elsők azért szállnak el, mert a gyár a "bejáratáshoz" valami más olajat tesz be. Nem véletlenül ajánlják, hogy 5ezernél cseréld le.
isa1562007-03-24 09:14:57 // 14935
A 99 es 2.0 TS ben 80 e nél lett cserélve, azóta 60 e-t mentem vele, amiben rengeteg 1-2 km es városi használat van Eddíg még jól bírja. Nemsokára viszem vezérmű felújításra. Nem tudom érdemes e hozzá nyúlni.
Nasty2007-03-23 17:20:33 // 14934
Alsó lengőkar cserét tervezek holnapra. Van vmi különleges instrukció vagy értelemszerű az egész? Nem akarok a cserért külön még pénzt kiadni.
Haro2007-03-23 10:48:44 // 14933
Minimum!!!!!!!!!!!!!
kertecs2007-03-23 10:46:43 // 14932
Hiszen leginkább erről szól a 60E km-s szervíz ezeknél motoroknál. Nem? : )
Haro2007-03-23 10:42:22 // 14931
Bocsi nem neked akartam irni!!!:)
Üvegtigris2007-03-23 10:41:48 // 14930
Tudom, hogy jócskán több, ezért írtam... : )
Haro2007-03-23 10:38:46 // 14929
A vezürmüszijjat és a görgöket mindenképp cseréld!!!
kertecs2007-03-23 10:38:23 // 14928
Maga a szíj? : )
Haro2007-03-23 10:38:01 // 14927
Jócskán több:))))
Üvegtigris2007-03-23 10:35:58 // 14926
A szíj+feszítő+munkadíj szerintem egy kicsit több 5-8 e Ft-nál, vagy nem? : )
kertecs2007-03-23 09:56:27 // 14925
Hali! A vez.szíj csere mindenképp, de nem is ez drága részlet az egészben, kb 5-8E Ft.
A hosszbordás szíjra gondolnak szerintem(ami a generátort, kormányszervót, klímát hajtja) , aminek állapotától függhet a csere.
Stef2007-03-23 07:51:18 // 14924
Köszi Haro! Vezérműszij állapotát lehet elenőrizni, vagy azt mindenképp érdemes cserélni, és ha kijön csak akkor látni, hogy jó volt-e még? (ez most kicsit zavaros volt)...
Haro2007-03-22 22:59:22 // 14923
Ha alkatrész kell olcsobban szólj!!!
Stef2007-03-22 22:14:15 // 14922
Kösz mindenkinek. Holnap megkérdem Szamosi mestert is, ha 100 körül kijön, inkább odaviszem...
Liquid2007-03-22 21:36:59 // 14921
Keress egy megbízható szerelőt, aki látott már TS motort, és van célszerszáma. 100-ból bőven ki fog jönni.
Üvegtigris2007-03-22 20:24:07 // 14920
Ha van független szervíz, amelyben bízol, akkor érdemesebb odavinni /gazdaságosabb és még lehet, hogy jobban oda is figyelnek rá, ha van ismerős, stb.../, de ha nem vág földhöz az a 30000 többlet , akkor vidd a márkaszervízbe.
Piritu - 1.000.0002007-03-22 20:16:58 // 14919
Bizony volt kerepelés, úgyhogy gariban csere lett belőle. Mind a három TS-emben cserélve lett a cucc. Viszont, amit a 146-ba tettek utána vagy 140e km-en működött. Szóval eddig amit betettek, már nem szorult cserére.
Haro2007-03-22 18:22:40 // 14918
Szerintem böven kijönn 100-ből de akkor minden pöpec!
Stef2007-03-22 18:20:51 // 14917
Tehát nagyjából 90-100-ból kijön? Egyébként amit munkaként leirtak, az megegyezik a szervizkönyvben leirt 60k-s szervizzel, csak kicsit (?!) sokalltam az árát. Volt mostanában valaki szakszervizben 60k-s karbantartáson? Szamosiéknál mennyi lehet? (Holnap fel is hivom)...
Haro2007-03-22 18:14:25 // 14916
Hali!!! Ennyiért nehogy megcsináltasd!!!! Ha kell tudok jó szerelöket ajánlani!
Poló2007-03-22 18:12:18 // 14915
Motorolaj és szűrők cseréje reálisan 20.000 Ft (nem tudom, itthon cseréltük).
Olaj kb 10.000 Ft (akciósan), olajszűrő kb. 1.000 Ft, légszűrő 2.600 Ft, pollenszűrő kb. 1.200 Ft. Munkadíjnak számoljunk 1 órát, az 4-5 eze Ft.
Vezérlés csere nálam majdnem 60.000 Ft volt anyaggal munkadíjjal együtt.
Az átvizsgálásra is számolhatunk szerintem egy órát, 4-5ezer Ft.
Szerintem inkább ne vidd márkaszervizbe, amúgyis csak lehúzzák az embert.
